vinrich
Nov 20, 2018Aspirant
Devices keep connecting to 2.4GHz on my Orbi RBK50
I'm having an issue with my Orbi. Whenever my devices are connected to the main Orbi router, it's always on 2.4GHz. However, when they are connected to the Orbi Satellite, it's 5GHz. I've tried reset...
Nov 20, 2018Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
\what devices do you have?
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
vinrich wrote:
I'm having an issue with my Orbi. Whenever my devices are connected to the main Orbi router, it's always on 2.4GHz. However, when they are connected to the Orbi Satellite, it's 5GHz. I've tried resetting my Orbi router. And it's still the same
