johnbday
Dec 31, 2019Tutor
Devices looking for wireless network restricted to 2.4GHz
Have been considering candidates for a smart line-voltage thermostat (electric baseboard heater), preferably without the need for a hub. The highest rated appears to be a Mysa <link not permitted> ...
Dec 31, 2019Guru - Experienced User
many of them are going to say that because customers don't know how to set them up, and they don't want to deal with having to help people get them setup.
I'm running an ecobee right now on an orbi setup. Works fine. Setup went fine.
There's a few work arounds to get them running sometimes but it usually isn't to much of an issue.
I can't attest to your "smart line-voltage thermostat" .
Worst case scenario is buying a super cheap 2.4ghz router and run it in AP mode for devices that have issues. You could either just run it all the time or you can use it for the setup process. I've actually done that when Orbi first came out and was having major issues with this. I had the cheap router setup with same ssid and password. I'd get the device all setup, turn off el-cheapo router, and then turn my orbi back on and it'd link to the orbi. i haven't needed to do that in a long time but it worked when the Orbi was still pretty beta.
- SW_Dec 31, 2019Prodigy
plemanssuggestion is simplest. I had also done that in early Orbi days with 2.4GHz only SSID via an old Asus router.
Fortunately, there's workaround via Orbi Guest network. Basically, you can setup separate 2.4GHz and 5GHz SSIDs via Guest network. If you're comfortable with telnet cmd, check out this post: How to separate SSIDs on Guest Network.
