Georgepy
Feb 07, 2021Follower
Devices lose connection to Orbi RBK13
I can set up my Orbi RBK13 and get wifi connection. But, devices will lose a connection and will not reconnect automatically or manually. It gives the message couldn't find IP address. I thought th...
randomousity
Feb 13, 2021Luminary
First, how technical are you? Second, are you able to log onto the Orbi from any device, by any means (wired, wireless, web interface, Orbi app)?
Do you understand DHCP and static IP addresses? Do you have access control enabled on your Orbi? If so, is it set to block or allow new devices by default? Is your problem limited to just a particular device, or all your devices?
