vcdxb
Sep 04, 2019Aspirant
Devices losing wifi but wired devices working fine - Orbi
I bought Orbi RBR50 (including sattelite) almost a year ago and everything has been working fine up until now. all of sudeen few weeks ago the wifi started to drop from devices and wouldnt connect ev...
Sep 04, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Has a factory reset and setup from scratch been performed since last update?
vcdxb wrote:I bought Orbi RBR50 (including sattelite) almost a year ago and everything has been working fine up until now. all of sudeen few weeks ago the wifi started to drop from devices and wouldnt connect even if i did forget network and re-type the access password. while all devices connected through LAN have been working fine without any interuptions. so my internet connectivity is fine but some issue with the wifi.
the other thing i' am noticing is that my wifi signal in certain areas of the house drops to 1 or 2 bars even though i' am very close to the main unit. i have a feeling that wifi is not getting transffered between the main unit and the sattelite when i move around the house.
this is really frustrating me and i have to keep re-setting the router at which point everything connects and works for me.
my current firmware version is V2.3.5.30. please help.
vcdxb
Sep 06, 2019Aspirant
Hi
Huawei EchoLife HG8240H
What is the size of your home? Sq Ft? 1650 Sq Ft
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected. - I dont know the exact distance but rougly it was 20ft but thats with 2 thick walls. I just moved the satellite further to make it around 25ft now and will monitor is the wifi drops again. but what is starange for me is that i've been using with the exact setup (20ft) for almost an year and i've had this issue before. it only started few weeks ago.
2.4 Ghz is Auto and 5Ghz is 36. given that i have relocated the satellite I will wait before I make any changes here to see if the issue persists. Or do you recommend i change the channel anyway?
a couple but very weak signal inside my house.
No
- FURRYe38Sep 06, 2019Guru - Experienced User
vcdxb wrote:Hi
This ONT has a built in ruoter and wifi.
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopWhat is the size of your home? Sq Ft? 1650 Sq Ft
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected. - I dont know the exact distance but rougly it was 20ft but thats with 2 thick walls. I just moved the satellite further to make it around 25ft now and will monitor is the wifi drops again. but what is starange for me is that i've been using with the exact setup (20ft) for almost an year and i've had this issue before. it only started few weeks ago.Lets see if this changes anything.
2.4 Ghz is Auto and 5Ghz is 36. given that i have relocated the satellite I will wait before I make any changes here to see if the issue persists. Or do you recommend i change the channel anyway? See if the problem appears again, if it does, change the channel.
Any Wifi Neighbors near by? If so, how many?a couple but very weak signal inside my house.
No This maybe needed as a last resort. Some FW Updates need a factory reset to ensure the system is cleared out and setup well from scratch.
