mrsubtraction
Mar 20, 2023Guide
Devices mysteriously blocked in Access Control list
Immediately following a recent reset of my cable modem, several devices on my network could no longer access the internet. (Documented in this discussion from a week and a half ago.) After tons o...
Mar 21, 2023Guru - Experienced User
I've never seen it happen randomly but I have seen a family member do it to mine. Not knowing what they're doing while using an app or one of my turd monkey playing with my phone cause it.
- WeemsWMar 24, 2023Aspirant
nternet service provider (ISP).RBKE963B: This is likely your router, which handles traffic between your local network and the internet. It may also provide other features such as VPN, parental controls, and QoS.Trendnet TEG-S380: This is likely an unmanaged network switch, which allows you to connect multiple devices to your network using Ethernet cables.GS716T: This is likely a managed network switch, which provides more advanced features than an unmanaged switch, such as VLANs, QoS, and traffic shaping.pi-hole: This is a network-wide ad blocker and DNS sinkhole, which can help improve network performance and security by blocking unwanted traffic and ads.
