mrsubtraction
Mar 20, 2023Guide
Devices mysteriously blocked in Access Control list
Immediately following a recent reset of my cable modem, several devices on my network could no longer access the internet. (Documented in this discussion from a week and a half ago.) After tons o...
Mar 21, 2023Guru - Experienced User
I've never seen it happen randomly but I have seen a family member do it to mine. Not knowing what they're doing while using an app or one of my turd monkey playing with my phone cause it.
WeemsW
Mar 23, 2023Aspirant
nternet service provider (ISP).RBKE963B: This is likely your router, which handles traffic between your local network and the internet. It may also provide other features such as VPN, parental controls, and QoS.Trendnet TEG-S380: This is likely an unmanaged network switch, which allows you to connect multiple devices to your network using Ethernet cables.GS716T: This is likely a managed network switch, which provides more advanced features than an unmanaged switch, such as VLANs, QoS, and traffic shaping.pi-hole: This is a network-wide ad blocker and DNS sinkhole, which can help improve network performance and security by blocking unwanted traffic and ads.
