Ltripreno
Mar 02, 2020Aspirant
Devices not connecting in mesh network??? Orbi RBK50
I have the RBR50V2 mesh router and 1 satelite that came in the RBK50 kit. I have read a couple of threads about this topic. I don't have a managed switch and I don't understand back haul. I think ...
- Mar 05, 2020
That means that the AV receiver was using a Static IP rather than Dynamic IP from DHCP. And since the static IP was for a different subnet than the 192.168.1 subnet of your Orbi, it was not seen on the network. Glad you got it figured out now. Since you set the static IP to 192.168.1.90, I suggest adding that to the DHCP Address Reservations under the Advanced -> Setup -> LAN Setup page of the web interface to the Orbi. That way nothing else will get assigned a conflicting IP by DHCP if your receiver is off the network.
Ltripreno wrote:SOLVED!!!!
Thank you, everyone for your ideas!
I was thinking more about the IP address.
The reciever IP address was 192.168.182.1. It was configurable, so I changed the .1 to a .5
The app has the ability to put in specific IP addresses for which the app would search. I put in the .5 address. No go.
Everything else is 192.168.1.xxx. A 1 where the receiver had 182.
I went to the receiver and put in 192.168.1.90, then put that in the app. Voila!! It worked.
Don;t ask why or how...I have no idea. But it worked.
Thank you all again!! I love forums like these!
Cheers,
Ltripreno
Tried these suggestions.
I turned down the power of the 5g to 25%. I unplugged the satelite and moved to where the tablet was on the 2.4 band.
No luck. Same results. The app does not see the receiver.
I forgot the network and reconnected several times to ensure I was on the 2.4 band.
So, I guess it is not the router's problem. I will bug Yamaha some more.
Oh, and I fixed the Akruto syncing problem. Not router related.
Thanks for your help and suggestions. Much appreciated.
Cheers,
Retired_Member
Mar 03, 2020
Ltripreno wrote:Tried these suggestions.
Cheers,
what are you so concerend about the app? Do these devices actually work? If not, then it's a bigger problem beyond the app. If they do work, forget the app.
