Ltripreno
Mar 02, 2020Aspirant
Devices not connecting in mesh network??? Orbi RBK50
I have the RBR50V2 mesh router and 1 satelite that came in the RBK50 kit. I have read a couple of threads about this topic. I don't have a managed switch and I don't understand back haul. I think ...
- Mar 05, 2020
That means that the AV receiver was using a Static IP rather than Dynamic IP from DHCP. And since the static IP was for a different subnet than the 192.168.1 subnet of your Orbi, it was not seen on the network. Glad you got it figured out now. Since you set the static IP to 192.168.1.90, I suggest adding that to the DHCP Address Reservations under the Advanced -> Setup -> LAN Setup page of the web interface to the Orbi. That way nothing else will get assigned a conflicting IP by DHCP if your receiver is off the network.
Ltripreno wrote:SOLVED!!!!
Thank you, everyone for your ideas!
I was thinking more about the IP address.
The reciever IP address was 192.168.182.1. It was configurable, so I changed the .1 to a .5
The app has the ability to put in specific IP addresses for which the app would search. I put in the .5 address. No go.
Everything else is 192.168.1.xxx. A 1 where the receiver had 182.
I went to the receiver and put in 192.168.1.90, then put that in the app. Voila!! It worked.
Don;t ask why or how...I have no idea. But it worked.
Thank you all again!! I love forums like these!
Cheers,
Ltripreno
Mar 04, 2020Aspirant
tomschmidt wrote:Ltripreno, you state that you have your AV receiver connected to the 2.4GHz WiFi band (at least according to the Orbi Attached devices display). Do network sources of the AV receiver work (pushing the NET: button on your remote)? If they work, then the problem has to be some incompatibility with the app if it cannot find the AV receiver, even when you force your tablet and/or phone to use the 2.4GHz frequency instead of the 5GHz frequency. Did you make sure your phone test also had your phone on the 2.4GHz frequency?
That is where I am at with Yamaha. I trried playing Net radio and Pandora through/from the AV receiver. It did not work.
I am waiting for Yamaha to respond with next steps.
Thanks!
theoak
Mar 05, 2020Luminary
There is always the obvious. I had a satellite receiver that I spent hours trying to figure out why it would not connect to the internet ... the antenna was not screwed in all the way :smileyembarrassed:
According the specs on the receiver, it does have a network port. Do you have a long network cable to try a direct connection to your router or satellite? Could you temporarily bring the satellite to where the receiver is and connect the receiver to the satellite via cable?
- theoakMar 05, 2020Luminary
I kind of glossed over it too ... but are you using Circle or Armour or any other type of security appliance?
I have a UTM device that just implemented a "Threat Prevention" module where web sites are ranked according to "reputation" essentially on a scale of 1 being good to 5 being bad. So I set my network to 4 to block supicious and high risk sites - sounds good right?. Netflix stopped working, my satellite reciever stopped working ... the sites these apps/devices are connecting to is crazy.
I would also try turning off any "security" to start off with to make sure Yamaha is not trying to connect to someting that the security appliance may consider "bad".
- LtriprenoMar 05, 2020Aspirant
theoak wrote:I kind of glossed over it too ... but are you using Circle or Armour or any other type of security appliance?
I just spent a fair amount of time reviewing every darn screen in the Orbi administrative area...security, setup, etc. I could not find anything that seemed like it would block anything. I can't find any mention of Armour. I did see Circle...it is not active.
I did upgrade the firmware. No chnage.
SOLVED!!!!
Cheers,
- tomschmidtMar 05, 2020Virtuoso
Cheers,
- FURRYe38Mar 06, 2020Guru - Experienced User
I presumed the AVR had already been using 192.168.1.something. :smileyembarrassed:
Glad you found this out. Interesting. Glad it's working now.
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
Cheers,
