rdiniz1111
Apr 16, 2022Aspirant
Devices not connecting to 5g even being 1ft away from router
Hello everyone, my main problem is stated on the subject: my devices are not connecting to 5g even being 1ft away from router/satellite, on the same room, no blocking objects. When I try to change ...
rdiniz1111
All do them connect to 5g but switch back to 2g very soon, in a couple minutes.
Ex: iPhone 11, MacBook, ps5, xiaomi stick
CrimpOn
Apr 16, 2022Guru - Experienced User
This is indeed strange. As long as the Orbi is broadcasting both channels, the device determines which it will use.
There appear to be methods to force a MacBook to use only the 5G WiFi:
and one that mentions iPhone:
