BabaOrbi
Feb 07, 2022Aspirant
Devices not connecting to Orbi RBK13 Satellite
Hi, I recently purchased a NETGEAR Orbi Whole Home Mesh WiFi System (RBK13) 1 Router & 2 Satellites. Installed the Orbi app and followed all the steps for setup of this new system. I put one of s...
Feb 07, 2022Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AC products. Most of the people who watch that forum are more likely to have experience with Orbi (WiFi5 RBK10, 20, 30, 40 and 50 Series). Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Thank you.
- BabaOrbiFeb 07, 2022Aspirant
Hi,
I have the firmware V2.7.3.22. I have xFinity as my internet service provider and I am using the NETGEAR C6900-100NAR Nighthawk Dual Band AC1900 Cable Modem Router.
The size of the home is 2500 sft, upper floor 1250 sft and the finished basement is of 1000 sft. So the setup i had was the Orbi router placed next to the Modem-Router, One of the satellite in the basement bedroom and the other satelllite placed in between the basement bedroom satellite and the Orbi router.
Thanks,
Baba
- FURRYe38Feb 07, 2022Guru - Experienced User
BabaOrbi wrote:
Hi,
I have the firmware V2.7.3.22. I have xFinity as my internet service provider and I am using the NETGEAR C6900-100NAR Nighthawk Dual Band AC1900 Cable Modem Router. Is the modem in router or modem only mode? Modem only mode is recommended.
The size of the home is 2500 sft, upper floor 1250 sft and the finished basement is of 1000 sft. So the setup i had was the Orbi router placed next to the Modem-Router, One of the satellite in the basement bedroom and the other satelllite placed in between the basement bedroom satellite and the Orbi router. What is the distance between the router and 📡 satellite(s)? is the modem and RBR in the basement or on the main level?
I saw the Netgear community and they do not recoommend to put the Router-Modem in modem only mode.
The distance between the router and satellites in not long, because I was testing to if distance was the issue by placing all the satellites with in a 20 feet distance from the router. And the Orbi router and my cable router-modem are on the first floor sitting side by side to each other.
