DWoodfield
Jan 30, 2021Aspirant
Devices not connecting to satellites RBS20
I have a CBR40 with 2 RBS20 Satellites. I have a 2 ROKUs and 1 Amazon Firestick and 1 Amazon express devices that I am attempting to connect to the Satellites. Even those the devices are right next t...
DWoodfield
Jan 31, 2021Aspirant
Thank-You for the information.
One satellite is certainly more than 30 ft away from the router the other is right around 30 ft away.
The satellites are currently daisy chained. I have however in the past seen them configured as hub and spoke.
If there a preferable way for them to be setup?
Each satellite is closer to the router than the other satellite so I was thinking that hub spoke would make more sense but was not sure how to force that configuration
Jan 31, 2021Guru - Experienced User
to force it you disable daisy chain from within the menu options
