mattleeds
Jul 13, 2018Aspirant
Devices not connecting to satellites
I have a number of devices which do not connect to a satellite, only the main router. Is this a known issue, and is there a way round this? It is preventing me from using some devices as they are loc...
mattleeds
Jul 15, 2018Aspirant
I am using v2.1.4.16 - how do I check the version of the individual devices?
One satellite is around 25-30ft from the router (through a floor and 2 walls), the other is around 40-50ft (through a floor and 4 walls). Both satellites are connected via Ethernet to the Gateway. One of the problematic devices is around 80ft from the router, 30ft from the satellite - this is one that refuses to connect to the satellite and instead tries to connect to the router (but does not have sufficient connection strength).
Jul 15, 2018Guru - Experienced User
Look at the routers connected clients list, this will show a list of satellites that are connected. There will be an IP address displayed with each satellite. You can connect to each satellite using its IP address...
What channels are you using? Try 1, 6 or 11.
Disable MIMO, Daisy Chaing and Fast Roaming on the router, apply and reboot.
I would try this, swap satellites around and see if the device will connect to it's closest satellite...Turn off the other satellites while your testing accept for one.
