ecniVgiB
Dec 10, 2020Aspirant
devices not connecting
Hi fellow forumers. I'm a mess! I'm sad, angry, frustrated and close to separating from my Orbi. Here is my story... For a long time my Orbi RBR50 and my two satellites have been working gre...
- Jan 05, 2021
"The ONLY issue I have is that I can’t go to access control. It seems turned off on the page while every other page tells me it’s set to access allowed. It’s just useful to see which devices have connected in case something is trying to jump on my network."
When you have Circle enabled, access control is not enabled.
Glad you got it all working. Please mark yoru thread as solved so others will know.
Enjoy. :smileywink:
ecniVgiB
Dec 11, 2020Aspirant
Thanks for your suggestions.
I have performed a hard reset (through the reset button in the back) which gave me a clean 2.6.1.40 firmware and I started my setup from scratch, NOT by restoring a backup. I didn’t configure anything and attempted to add the devices (one new DETA smart switch that are already used in the house and are working: didn’t want to connect, and my new Nest Protect: didn’t want to connect. Furthermore, most devices started to reconnect, with exception of some devices. Those devices I tried to reset and reconnect, without avail.
I wouldn’t know how revert to a previous firmware. I can’t find a place to download it.
My system is 75% back up, but still lots of weirdness when I try to Ethernet back haul the satellites.
I’m open to further suggestions in the hope it’s a software issue and not a hardware issue...
vajim
Dec 11, 2020Master
"I wouldn’t know how revert to a previous firmware. I can’t find a place to download it."
Look up at the top of this page for the DOWNLOADS link.
