funsurfer
Apr 04, 2021Initiate
devices "Not Responding' in HomeKit
I had lots of problems in Homekit using the Orbi mesh wifi but I finally found a solution and wanted to post it here since I could not find much info anywhere.
On the Orbi uncheck enable WMM (Wi-Fi multimedia) settings (2.4GHz/b/g/n)
If you have other Wi-Fi routers disable Airtime Fairness
https://support.lifx.com/hc/en-us/articles/360025083411-Airtime-Fairness
1 Reply
Sort By
- MoutailleAspirant
Hello,
I have this "no response" problem on my Homekit installation since months.
It started with a EVE Extend and I thought it was a problem of the Eve material.
I replaced it and I had the same issue.
Since 3 days, it is my ismartgate which has the same issue.
I know now that it's not a hardware problem but a Wifi problem.
I tried your solution but it stil doesn't work.
Would you have an other idea to help me ?!
Thank you in advance.
