rjs4262
Jun 05, 2021Aspirant
Devices not rolling to RBW30 Satellite from RBR40 Router like they used to
I've had my RBK30 (RBR40 + RBW30) Orbi system for like 51 weeks. All of a sudden in the past week, my wifi devices are losing their connection and taking forever to reconnect. I have concluded this...
Jun 05, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
rjs4262
1) Latest firmware (2.6.2.2)
2) BGW210-700 (AT&T Gigabit)
3) 3060 sq ft (1 story)
4) 35 ft
5) All my neighbors have wifi, but none of their systems are within reach insid emy home
6) Disable all of those at the same time, or one by one? And why woudl I need to do this all of a sudden. My system was flawless for 51 weeks, now it is a piece of garbage if you're near a satellite.
- FURRYe38Jun 05, 2021Guru - Experienced User
Try turning down the power output of the RBR to 50% and see.
