Accutronman
Apr 26, 2019Guide
Devices Not Showing Connected to Satellite on Network Map
Running latest firmware on RBR50. Devices sitting in same room as satellite show in network map on orbi app as being connected to satellite initially and then after a period of time show being connec...
Apr 26, 2019Guru - Experienced User
Try a factory reset and setup from scratch with new FW load.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
- BiGMERFApr 26, 2019Apprentice
I’ve rebooted several times trying to improve my crappy 125/200 WiFi speed on my century link gig fiber connection. Which incant seem to make better.. so truthfully with that issue alone this thing may go back to Best Buy. I got the same speeds on my two year old dual band Samsung connect mesh. I bought the Orbi thinking it would be better. At lest 400
anyway after all the rebooting my satellite still has nothing connected t it. Only shows the two wired items I have connected to it.. meanwhienthere is a Roku and echo dot right next to it that rather attach to the route 25 feet away
- AccutronmanApr 27, 2019Guide
2100 sq ft. Satellite within 30 ft of router. Did factory reset and reload prior to posting. No difference
