Accutronman
Apr 26, 2019Guide
Devices Not Showing Connected to Satellite on Network Map
Running latest firmware on RBR50. Devices sitting in same room as satellite show in network map on orbi app as being connected to satellite initially and then after a period of time show being connec...
Apr 26, 2019Guru - Experienced User
Try a factory reset and setup from scratch with new FW load.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Accutronman
Apr 27, 2019Guide
2100 sq ft. Satellite within 30 ft of router. Did factory reset and reload prior to posting. No difference
