Vanyel
Mar 27, 2018Aspirant
Devices not switching between Orbi Router and Satellite
Hi all, Pretty much as described in the subject. My android phone, Sony Xperia XZ Premium with Android version 8.0.0, keeps dropping wifi connection when switching between the Orbi Router and Sat...
Mar 27, 2018Guru - Experienced User
Does this still happen if you disable beamforming and MIMO or Fast Roaming?
Using any manual channels like 1, 6 ,or 11?
IF your windows laptop doesn't do this, this could a device issue and how they are handling roaming.
- VanyelMar 27, 2018Aspirant
Yes the disconnecting still happens even after i disabled beamforming, MIMO and fast roaming, i.e. disabled everything.
The only manual channel is 5ghz (48) which i believe should be for backhaul.
I know my laptop didn't disconnect when switching as i logged onto VPN and checked orbilogin to verify that the laptop's connection changed. Confirmed that the VPN remained connected as my laptop changed from satellite to router and vice versa.
- FURRYe38Mar 27, 2018Guru - Experienced User
Try enabling Beamforming only.
Might try setting up some IP address reservations and test...
This maybe a device issue rather than a router issue.
Thanks there is no change.
This is really frustrating as i expected, and was probably used to, seamless transition between Orbi router and satellite.
There was another change which might have caused this. I tried to set up a Samsung Connect Home a few days ago to use it as a smart hub. However, it needs to be set up as a wifi hub first. I connected the Connect Home to my Orbi satellite. After the set up, i set the Connect Home to bridge mode and disabled wifi. I noticed that the Orbi satellite was broadcasting the Connect Home wifi network even after i disabled wifi on the Connect Home.
Could this be the reason why my Orbi router and satellite network seems to no longer be in sync?
I have also tried to reset both the Orbi router and satellite but to no avail.
