Ryan1919
Oct 04, 2018Tutor
Devices not switching to satellites after 2.2.1.210 update
After firmware update my devices are not switching to the satellites when their closer to them than the router. Before the update I knew exactly when the device would switch to the satellite from the ...
cool2562
Oct 05, 2018Star
I had the same problem. The way I fixed it was to reset to factory defaults and set up from scratch.
Ryan1919
Oct 05, 2018Tutor
Are your satellites switching like they did before the update? The signal is way stronger from the router now which is why I think my devices aren't switching like they use to. The problem is if I turn down my transmit power to 50% for 5g then my devices connect to the 2.4g band because its stronger.
- FURRYe38Oct 06, 2018Guru - Experienced User
I would try with the router alone first and check signal and connections...The size of your home maybe too small for having the base router and satellites all running.
Let us know.
