Ryan1919
Oct 04, 2018Tutor
Devices not switching to satellites after 2.2.1.210 update
After firmware update my devices are not switching to the satellites when their closer to them than the router. Before the update I knew exactly when the device would switch to the satellite from the ...
cool2562
Oct 05, 2018Star
I had the same problem. The way I fixed it was to reset to factory defaults and set up from scratch.
Hawkmoth
Oct 07, 2018Star
Thanks for the suggestion to reset the rounter and set it up again from scratch. That also resolved my issue with devices not swithing to the satellite sfter updating firmware to version 2.2.1.210. I did see some devices on the satallite once in awhile, and those were idenitified with unknown for connection type. That also has been resolved by the reset.
