wised0nkey's avatar
Oct 13, 2019
Devices not working after firmware upgrade
Hi All, I have a RBR50, RBS50, and RBS40. I recently upgraded my firmware to V2.3.5.30 and shortly after noticed that certain devices were connecting to the router, but without internet access. Other...
  • plemans's avatar
    Oct 14, 2019
    Something is acting as a server. I doubt its t he ring chime pro. Did you try to access it via the 192.168.7.1?
    Another thing you could try would be to turn off all your devices (other than modem and router) and gradually add devices. At some point the device acting as the dhcp service is going to be turned on and start causing havok. thats basically your goal, find whats acting as the dhcp server.
