wised0nkey
Oct 14, 2019Tutor
Devices not working after firmware upgrade
Hi All, I have a RBR50, RBS50, and RBS40. I recently upgraded my firmware to V2.3.5.30 and shortly after noticed that certain devices were connecting to the router, but without internet access. Other...
- Oct 15, 2019
Something is acting as a server. I doubt its t he ring chime pro. Did you try to access it via the 192.168.7.1?
Another thing you could try would be to turn off all your devices (other than modem and router) and gradually add devices. At some point the device acting as the dhcp service is going to be turned on and start causing havok. thats basically your goal, find whats acting as the dhcp server.
Oct 15, 2019Guru - Experienced User
wised0nkey
Oct 17, 2019Tutor
You guys were right. I found that my in laws had plugged in a telephone router for a landline they were using. It's been there for a long time, so I'm not sure what happend after the firmware update. Anyway, that was definitely the culprit because after I unplugged it, the IP subnet went away and everything started working again. Thanks again everybody. This is great community.
- plemansOct 17, 2019Guru - Experienced User
wised0nkey wrote:You guys were right. I found that my in laws had plugged in a telephone router for a landline they were using. It's been there for a long time, so I'm not sure what happend after the firmware update. Anyway, that was definitely the culprit because after I unplugged it, the IP subnet went away and everything started working again. Thanks again everybody. This is great community.
Glad to hear you got it working and figured our which device decided to start handing out ip addresses.
