LucasRey
Mar 07, 2021Tutor
Devices offline (no Wifi connection) with no internet
Hello community, I have RBR50 with 2 satellities and all working fine except when internet connection goes down (e.g. reboot firewall/gw/modem or just where there is an issue from provider). I have...
LucasRey
Mar 09, 2021Tutor
Wait, I'm sorry to wasted forum space, my bad. :smileyfrustrated:
The RBR50 (firmware V2.7.2.104) and its 2 satellites (same firmware) work perfect and never drop the wifi connections during normal use. Rebooting the modem will result in drop internet but keep local wifi connection (that's ok). I got confused when I reboot pfSense firewall, I thought RBR50 drop local wifi connection but this is not true, simply WIFI Vs LAN goes down due to pfSense unavailability (so no routing).
However, thanks to FURRYe38 for reporting so many tips to increase RBR stability. I'll apply them asap since some times some ceiling lights goes offline for a while (and come back after a few minutes), that's happen rarely, so it's not a big problem.
vajim
Mar 10, 2021Master
Lots of complaints about firmware V2.7.2.104
all the best
- LucasReyMar 10, 2021Tutor
vajim wrote:Lots of complaints about firmware V2.7.2.104
So what's the firmware I have to install? the 2.72.104 is the latest one- vajimMar 10, 2021Master
So what's the firmware I have to install? the 2.72.104 is the latest oneIF 2.72.104 is giving you problems (like many have reported here) wouldn't it make sense to revert back (if possible) to the last one where you were stable?
Or..........you can stay where you are and wait for others here to pepper you with 1000s of questions about your problem
it's up to you
