Norfolkboy1111
May 08, 2018Aspirant
Devices on 2.4 ghz wifi unable to get an internet connection
Hi all,
I'm pulling my hair out with my orbi system at the moment. i recently changed to Virgin Media, and therefore the Orbi is now running in AP mode and devices that use the 2.4 wifi signal ...
May 08, 2018Guru - Experienced User
What Mfr and model# ISP modem do you have? Built in wifi and router here by chance?
If so, did you disable ALL Wifi radios here?
Did you walk thru the set up wizard on the orbi router to set it set up with your modem?
Any other wifi neighbors near by? If so, how many?
Try using channels 1, 6 or 11 on 2.4Ghz.
Set WPA and TPIK only, then try WPA2 and AES only security modes.
Disable MIMO, Daisy Chain and Fast Roaming...
What wireless devices do you have?
- Norfolkboy1111May 08, 2018Aspirant
Thanks for your reply.
i have a Virgin Superhub 3 running as the modem, and i have disbaled the Wifi on this.
will try the setting s you suggested, house is semi detatched so littl eother wifi signals close by, problem devives are two Android running phones plus an Amazon fire tablet- all threee wokred fine beofre the Orbi went into AP mode.
i could factory reset the whole Orbi system and start again and see if this has any effect.,
