pontke
Jul 13, 2020Aspirant
Devices on satellites cannot access devices on router
I have an Orbi system of one router and two satellites. The router is model RBR50 and the satellites are RBS50. All of them have firmware version 2.5.1.16. The issue I am facing is that devices...
CrimpOn
Jul 13, 2020Guru - Experienced User
I agree this situation is mysterious. It does not match my experience.
I have only one RBR50 router and one RBS50 satellite. Same firmware (2.5.1.16). When I duplicate your experiment, two laptops behave as expected. Ping when connected to the same router. Move one downstairs to the satellite and ping successfully again.
I also agree that firewall behavior is not behind this. It is correct that Windows Firewall does not respond to ICMP (ping) unless an exception is created. But "not respond" means (literally) "never respond. not even once." It's not the laptop firewall.
pontke
Do you think I might need to reset the router settings and start over setting it up? Any particular order of steps I should take?
- CrimpOnJul 13, 2020Guru - Experienced User
pontke wrote:
Do you think I might need to reset the router settings and start over setting it up? Any particular order of steps I should take?I remain totally stumped as to what could possibly cause this phenomenon. The "last resort" is to perform a Factory Reset and set up the Orbi again. Of course, use the same exact SSID and password so that all devices will connect automatically.
For my own Orbi, I have a goofy system of assigning IP addresses to about 35 devices. IP cameras start with 192.168.1.51, smart plugs with 192.168.1.31, all the TV's, desktops, Tivo's, DVD's, etc. are from 1.2 through 1.30. It's silly, but it made sense at one time (I guess).
To keep devices from connecting as soon as the Orbi "comes alive" and getting IP addresses that I do not want them to have, I put off naming the Orbi WiFi until after I have created all my IP assignments. So, my network is essentially "dead" for almost an hour before I change the SSID/password to the previous value and everything rushes to connect.
