Aaron2019
Apr 25, 2019Aspirant
Devices only connecting to 2.4 orbi band not 5ghz
Hello, Iv had my orbi for around a year now and only noticed as recently that I'm only connecting to the 2.4 GHz channel with phones and tablets etc regardless if it's on router or satelite. Phones...
Apr 26, 2019Guru - Experienced User
30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Aaron2019
Apr 27, 2019Aspirant
Ps. Tab s2 does seem to connect as 5ghz when sitting beside router.. But it swaps between 2.4/5 when glancing at page. It's not on or doing anything though and it's about 2 inches from router.
- FURRYe38Apr 27, 2019Guru - Experienced User
Has a factory reset been performed and setup from scratch after new FW has been loaded?
