Aaron2019
Apr 25, 2019Aspirant
Devices only connecting to 2.4 orbi band not 5ghz
Hello, Iv had my orbi for around a year now and only noticed as recently that I'm only connecting to the 2.4 GHz channel with phones and tablets etc regardless if it's on router or satelite. Phones...
Aaron2019
Apr 27, 2019Aspirant
Ps. Tab s2 does seem to connect as 5ghz when sitting beside router.. But it swaps between 2.4/5 when glancing at page. It's not on or doing anything though and it's about 2 inches from router.
Apr 27, 2019Guru - Experienced User
Has a factory reset been performed and setup from scratch after new FW has been loaded?
- Aaron2019Apr 27, 2019AspirantYes I said I factory reset today In previous post
- Aaron2019Apr 29, 2019AspirantBumping, tried factory reset phone but didn't help. Next option is reduce the power of 2.4 GHz band.. But that seems counter productive to the design?
- FURRYe38Apr 29, 2019Guru - Experienced User
I would file a support ticket and see about getting an RMA. Possible you have a faulty system.
