bkl123
Jul 28, 2021Aspirant
Devices randomly blocked by "Access Control in Router"
This week random devices that have been on my Orbi network for years have started showing this message in the browser. I've disabled access control completely, rebooted and the device will have acces...
Jul 28, 2021Guru - Experienced User
Have you set up IP address reservations for devices ON the RBR?
- bkl123Jul 28, 2021Aspirant
No devices have reserved IP addresses.
Router Firmware Version
V2.7.3.22I have not done a factory reset and re-setup. Trying to avoid it. Is there a way to save / apply the current config if a reset is required?Thanks for the help!- FURRYe38Jul 28, 2021Guru - Experienced User
Yes:
I would save a back up first, reset and set up from scratch first, set up some IP reservations for devices that you want to be controlled by Access Control and then see how it runs...
Thanks for the article.
Ok so if I want a device to be blocked by access control I should block it and assign it an IP address?
Also, I went in and removed one of the devices from the access control list entirely (even though it was in the 'allowed' list) and then rebooted and so far that device hasn't reverted to being blocked. So that may be another way to get to this problem resolved.
