bkl123
Jul 28, 2021Aspirant
Devices randomly blocked by "Access Control in Router"
This week random devices that have been on my Orbi network for years have started showing this message in the browser. I've disabled access control completely, rebooted and the device will have acces...
bkl123
No devices have reserved IP addresses.
Router Firmware Version
V2.7.3.22
V2.7.3.22
I have not done a factory reset and re-setup. Trying to avoid it. Is there a way to save / apply the current config if a reset is required?
Thanks for the help!
Jul 28, 2021Guru - Experienced User
Yes:
I would save a back up first, reset and set up from scratch first, set up some IP reservations for devices that you want to be controlled by Access Control and then see how it runs...
