Retired_Member
Sep 03, 2021DFS channels for ORBI RBR20
This KB seems to indicate that my RBR20 should support DFS channels in the FCC regulatory domain. https://kb.netgear.com/000060378/Which-Dynamic-Frequency-Selection-channels-does-my-NETGEAR-devic...
Sep 03, 2021Guru - Experienced User
it uses them for the backhaul
Retired_Member
Sep 03, 2021Interesting. My Wi-Fi Analyzer app isn't showing them beaconing on the DFS channels so it must be using those frequencies with some protocol other than 802.11 a/n/ac...
Thanks for the reply
- plemansSep 03, 2021Guru - Experienced UserIt could be your in a region that has active dfs broadcasts.
- CrimpOnSep 03, 2021Guru - Experienced User
The channels used are described on page 159 of the user manual:
https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
US: 5.18 - 5.74 GHz (front haul) and 5.745 - 5.875 (backkhaul)
Europe & Japan: 5.18 - 5.24 and 5.5 - 5.7
Translated to channel numbers this is:
US: 36 - 48 and 149 - 175 (backhaul)
Europe & Japan: 36 - 48 and 100 - 140 (backhaul)
There is a note on page 159 about another frequency band becomming available with future firmware (whatever that means).
- Retired_MemberSep 03, 2021
Ah, it looks like they avoided the DFS channels for the US models. From that reference:
5.18 GHz–5.24 GHz and 5.745 GHz–5.825 GHz (US)
Neither of these two bands requre DFS in the US/FCC
I was looking for support in these bands:
(5250 - 5350 @ 80), (23), DFS, AUTO-BW (5470 - 5730 @ 160), (23), DFS These are channels 52-144. The original kb.netgear document I referenced indicated that these DFS channels were supported
Orbi Router / Orbi Satellite
(Models: RBR20, RBS20)52,56,60,64,100,104,108,112,
116,120,124,128,132,136,14054,62,102,110,118,126,134
58,106,122
42+58,42+106,42+122,
58+106,58+122,106+122NA
Although I note that in user guide you referenced they are not.
- FURRYe38Sep 03, 2021Guru - Experienced User
DFS channels are not available for user selecting on any Orbi system. Only channels 36 thru 48. ALL higher channels, usually 149 thru 165 are for the wireless backhaul channels used only by the orbi system.
