AustinBike
Apr 08, 2018Star
DHCP - Need to release IP addresses
Why can I not release IP addresses? Even with a reboot it still holds on to old addresses. I created a reservation and when I look in the clients list I see 3 different addresses for the same device.
- st_shawMaster
You need to reboot your devices (not Orbi) to get the devices to release their IPs. Also, make sure your devices are set to use DHCP to get an IP and don’t have hard coded IP addresses.
- Devices have been repeatedly rebooted, IPs remain.
- st_shawMaster
AustinBike wrote:
Devices have been repeatedly rebooted, IPs remain.Ok. Then something is not right somewhere. If you set your client devices to use DHCP and reboot them, they will obtain one IP address only. If you reboot Orbi, the list of attached devices will be cleared. Sounds like there might be more than one DHCP server on your network, like an old router or something.
In order to help, we would need more information on your network. Also need a complete description of what you are looking at that indicates you have a problem. A screenshot would be helpful there.
What modem/router(s) do you have, how are they connected, in what order are they connected, is Orbi in AP mode or router mode, what type of client device is exhibiting the problem, is there more than one client device with the problem...
What FW version is loaded on the Orbi router?
AustinBike wrote:Why can I not release IP addresses? Even with a reboot it still holds on to old addresses. I created a reservation and when I look in the clients list I see 3 different addresses for the same device.
2.1.3.4
just plugged it back in and powered it up after 24+ hours off line.
The reaerved IP at 192.168.1.99 that I set for the garage door is there, but so is the old 192.168.1.162 that was dynamically assigned days ago.
i did name the device when it was .162. Can’t find a way to release this.
- st_shawMaster
AustinBike wrote:
2.1.3.4
It's still hard to help you without more specific information on what is going on.
What exactly do you mean 1.99 is there but so is the old 1.162? The IP is where? Where are you seeing two IPs listed? On the Orbi attached devices screen?
I believe all that Orbi is doing is reporting devices that respond to arp.
Is this garage door device the only device exhibitng this behavior? Can you actually connect to the device at bith IP addresses? I would look at your device as the possible culprit.
Anyway... if this is not causing you any actual network problems you should be able to ignore it. There is no rule against one device having two IPs. You just cannot have one IP being used by two devices.
- SaunderAspirant
Is the Orbi RBR50 compatable with a Nord VPN ? I need to connect a vpn to my router to stream pictures from my windows 7 pro.
to my samsung smart tv. HELP
I recommend you make a new post about your question regarding VPN. This thread is dealing with DHCP and reservations.
Saunder wrote:Is the Orbi RBR50 compatable with a Nord VPN ? I need to connect a vpn to my router to stream pictures from my windows 7 pro.
