JTBusfield
Mar 19, 2018Follower
DHCP - which to assign? Modem or Orbi?
Folks, I have set up the Mini Orbi system (sucessfully) in my 2500 sq ft home with FiOS. I disable the wireless in the FiOs modem, but left the DHCP on. I did not set the Orbi up as an AP. So I k...
st_shaw
Mar 19, 2018Master
JTBusfield wrote:
Folks,
I have set up the Mini Orbi system (sucessfully) in my 2500 sq ft home with FiOS. I disable the wireless in the FiOs modem, but left the DHCP on. I did not set the Orbi up as an AP. So I know have two devices doing DHCP, which I should not, I know. But which is best? It seems like the IP addresses on my devices are all in the Orbi range, not the FiOS. SHould I disable the FiOs or the Orbi DHCP function?
Thanks for any advice.
Joe B.
Assuming you have the Orbi Internet port wired to your FIOS router, if you disable the FIOS DHCP server, then Orbi will stop working. The Orbi Internet port needs to get an IP address to work.
Your simplest, and likely best, option is to change Orbi to AP mode. Then everything will be on the FIOS LAN.
