JTBusfield
Mar 19, 2018Follower
DHCP - which to assign? Modem or Orbi?
Folks, I have set up the Mini Orbi system (sucessfully) in my 2500 sq ft home with FiOS. I disable the wireless in the FiOs modem, but left the DHCP on. I did not set the Orbi up as an AP. So I k...
nicholb
Mar 20, 2018Luminary
The two most common ways to set this up are
1. Put the FiOs modem/router in transparent bridge mode and the Orbi in Router mode. This lets the Orbi do all the router type functions like firewall and DHCP.
2. Just disable the WiFi on the FiOs leaving everythign else running and set the Orbi into AP (access point) mode. Then the FiOs will do the router functions and the Orbi will just be handling WiFi.
Leaving both with router functions can cause issue with the double NAT and two firewalls.
