JTBusfield
Mar 19, 2018Follower
DHCP - which to assign? Modem or Orbi?
Folks, I have set up the Mini Orbi system (sucessfully) in my 2500 sq ft home with FiOS. I disable the wireless in the FiOs modem, but left the DHCP on. I did not set the Orbi up as an AP. So I k...
Mar 20, 2018Guru - Experienced User
What IP address is the Orbi router getting from the FIOS router on it's internet port?
Did you set up the DMZ on the FIOS router for the Orbi router? You can use this and have good opertation using the DMZ on the FIOS router.
