MachThree's avatar
MachThree
DHCP Address reservations ignored?
Hi all - In the router config I've reserved configured DHCP to reserve IP addresses for several of my devices.  Some of the devices end up using their reserved addresses but some I cannot seem to get...
  • FURRYe38's avatar
    Nov 12, 2018
    What FW version are you using?
    What is the size of the default DHCP Address pool? If default, try setting the following size:
    192.186.1.100 to .200. Then set up an IP address for your devices with in this new pool size. Select Add and Apply. Make sure the devices are set for auto obtain IP addressing. I would reboot the devices after changes are made on the router. After you hit apply, you might want to do a fully reboot then reboot all the rest of the devices.
