marabubout
Apr 10, 2020Aspirant
DHCP connection
Hello, I'm trying to set up my RBK50 in order to receive a second IP adress from my ISP as recommanded there: https://www.proximus.be/support/en/id_sfaqr_router_install/personal/support/internet...
Apr 10, 2020Guru - Experienced User
You're trying to connect the RBR50 to an existing router?
Is that what you're trying to accomplish? If not, maybe explain what you're setup is and what your trying to accomplish. Linking to something else doesn't explain what you're trying to do with your setup.
If you are trying to setup orbi with an existing router, you'd want to use access point modem on the rbr. That allows your existing device to run dhcp/routing functions and uses the orbi for wireless/ethernet connections.
