VincenzoV
Jul 13, 2019Aspirant
DHCP for /16 netmask (Legacy class B network)
Hi all I need a /16 (class B) network in my LAN (172.16.x.z/16). DHCP work fine, but I can't set byte 3 in DNS: it's grayed! I need DHCP range from 172.16.1.0 to 172.16.255.254 Orbi RB50, firmwa...
Jul 13, 2019Guru - Experienced User
"I need DHCP range from 172.16.1.0 to 172.16.255.254" This is not a valid networking range for home class routers. Or any networking router.
172.16.1.1 thru .1.254 is valid or 172.16.255.1 thru .254 is valid.
VincenzoV wrote:Hi all
Orbi RB50, firmware V2.3.1.60
Thanks
- VincenzoVJul 14, 2019Aspirant
FURRYe38 wrote:This is not a valid networking range for home class routers. Or any networking router.
I need a /16 network (legacy class B), not a /24 (legacy class C)
- 172.16.0.0/16 is the network address
- 172.16.0.1/16 is the first valid address (tre Orbi gateway)
- up to 172.16.0.255/16 will be, in my network, static IPs
- from 172.16.1.0/16 to 172.16.255.254/16 will be under DHCP server control. This is my problem with Orbi: I can't set it!
- 172.16.255.255/16 is the broadcast address
- FURRYe38Jul 14, 2019Guru - Experienced User
This is probaby not supported by Orbi. It's DHCP services are simple for home class networks.
Sounds like you need a business calss router.
