Nicolas72
Jan 03, 2019Guide
DHCP issue with ORBI RBK50 configured in AP mode
I recently replaced my old Apple Airport Extreme by a brand new Orbi RBK50. I'm running the last FW 2.2.1.210.
The Orbi (RBR) is configured in AP mode and one satelite (RBS) is configured in wirele...
ekhalil
Jan 03, 2019Master
When you set Orbi to AP mode you get a question about IP addressing responsibility as follows:
1) Depending on what you selected, Orbi will direct all Attach requests from devices to the router or not. Please check this setting
2) Is the DHCP server address defined in your router?
Nicolas72
Jan 03, 2019Guide
Hi,
Thank you for your reply!
When configuring AP mode I selected the first option "Get dynamically from existing router".
Orbi as an AP did recieve an IP from the fronted switch (acting as a DHCP server). The IP recieved from the switch is in the good range.
It means the communication between Orbi and the switch is working well.
My wireless connected devices sometime receive an IP in the same and good range but most of the time recieve an IP from the "default range" 169.254.X.X with no gateway and an incorrect network mask which correspond to no connectivity ...
Of course, everything goes well If my wireless devices recived a good network address configuration and vice versa.
Strange behaviour knowing that my previous Apple Extreme worked fine in the same topology and configuration during 5 - 6 years.
Best Regards.
- ekhalilJan 03, 2019Master
Nicolas72 wrote:
Hi,
Best Regards.
The only thing that I can think of now is: When you changed from the Apple Airport to Orbi, did you use the same SSID? I'm afraid that your devices still have the routing information that it got when it initially attached through the Apple Aiport which I'm not sure if it will be correct to use with Orbi.
Does forgrtting the network from the device and attaching again help? Otherwise a change of the SSID woths also trying!
- Nicolas72Jan 03, 2019Guide
Hi,
Yes I keep the same SSID but I forgot the network on wireless devices and reconnected. I aso tried to change the SSID and I also restarted the AP.
Still the same issue.
I discovered some strange behaviour yesterday evening. One of my wireless device sucessfuly connected to the network and it apparently received an IP from an already connected wired device (when I came to my wired device I saw the error "An other device use your IP address".
It never happened while runing my old Airprt. I am not sure but it's like getting an IP via DHCP from Orbi AP was not the same as getting an IP via the same DHCP from a wired connection (like the AP is also acting as a DHCP).
I guess I'm right if I say turning Orbi into AP mode disable its DHCP feature?
Best Regards
- ekhalilJan 04, 2019Master
Nicolas72 wrote:
..........I guess I'm right if I say turning Orbi into AP mode disable its DHCP feature?
Yes, once Orbi is on AP Mode the DHCP functionality should be diasabled.
Nicolas72 wrote:
.......I discovered some strange behaviour yesterday evening. One of my wireless device sucessfuly connected to the network and it apparently received an IP from an already connected wired device (when I came to my wired device I saw the error "An other device use your IP address".
Do you have any extenders/repeaters or Wifi-LAN converters? Those devices have built-in DHCP servers and I noticed that sometimes they can interfere with the main DHCP server.
Please get the following information that will give us information about the configuration in Orbi:
- From a browser go to the router's debug page (http://192.168.1.1/debug.htm). Use your router's IP address
- Enter admin as user name and your router’s management password
- Tick "Enable Telnet" option
- Use Telnet to connect to your Router telnet 192.168.1.1 (use your router's IP address) and enter admin and the same password as above
- Enter the following commands, and copy the output printout:
config get lan_dhcp
config get lan_proto
config get ap_dhcp_ipaddr
config get ap_dhcp_gateway
- config get ap_dhcp_netmask
- config get bridge_dhcp_ipaddr
config get bridge_dhcp_gateway
config get wan_proto
config get wan_dhcp_gateway
config get wan_dhcp_server
config get config get bridge_dhcp_netmask
