computersteve
Jul 19, 2020Apprentice
DHCP issues after Orbi in AP Mode RBK50 reboot
netgear Something is wrong with DHCP after a reboot of my main router (UBEE), & the way it interacts with the Orbi system. I have an UBEE modem which also acts as router with DHCP provided through my...
CrimpOn
Jul 19, 2020Guru - Experienced User
computersteve wrote:First, having the UBEE fully restartarted / online. Then 1 by 1 replugging everything else in. Next, the main Satellite or Router (AP Mode).
It would help to know what "replugged" means. (ethernet cord pulled and reinserted or powered off and back on).
If devices are restarted (powered off/on) when the Orbi is not connected to the UBEE, then they should all attempt to get an IP using DHCP, fail to get one, and then set themselves to their "default" 169.x.x.x address.
When I restart my modem, or even restart my Orbi, I never power off any devices. Since you are able to reach the ISP tech support line, it would be useful to know what the UBEE "DHCP Lease Time" is. The Orbi default, for example is one day (86,400 seconds). Devices are supposed to begin asking to renew their IP address when half of the lease time remains and keep doing so periodically until the lease expires. If the UBEE DHCP lease is very (very ) short, then devices could possibly "time out" on the renewal while the Altice is powered off. If the UBEE is simply being "restarted", this seems a remote possibility.
I believe the reddit post mention was about Orbi in router mode, not AP mode.
So, I have no explanation, only questions.
computersteve
The problem is it doesn't recieve IPs after the UBEE reboots.. If I run a wireshark it says that its then sending request to 192.168.1.255 meanwhile my gateway (UBEE) is 192.168.1.1.. If I reboot everything it then works and it resumes recieving IP's from 192.168.1.1
- CrimpOnJul 19, 2020Guru - Experienced User
computersteve wrote:The problem is it doesn't recieve IPs after the UBEE reboots.. If I run a wireshark it says that its then sending request to 192.168.1.255 meanwhile my gateway (UBEE) is 192.168.1.1.. If I reboot everything it then works and it resumes recieving IP's from 192.168.1.1
I have lost track of what "it" is. Is Wireshark recording packets from the machine that Wireshark is running on?
Wikipedia explains DHCP requests as starting with a "broadcast" to IP 255.255.255.255 and then waiting for the first DHCP server to respond. With the Orbi in AP mode, that should be the UBEE.
