computersteve
Jul 19, 2020Apprentice
DHCP issues after Orbi in AP Mode RBK50 reboot
netgear Something is wrong with DHCP after a reboot of my main router (UBEE), & the way it interacts with the Orbi system. I have an UBEE modem which also acts as router with DHCP provided through my...
computersteve
The problem is it doesn't recieve IPs after the UBEE reboots.. If I run a wireshark it says that its then sending request to 192.168.1.255 meanwhile my gateway (UBEE) is 192.168.1.1.. If I reboot everything it then works and it resumes recieving IP's from 192.168.1.1
CrimpOn
Jul 19, 2020Guru - Experienced User
computersteve wrote:The problem is it doesn't recieve IPs after the UBEE reboots.. If I run a wireshark it says that its then sending request to 192.168.1.255 meanwhile my gateway (UBEE) is 192.168.1.1.. If I reboot everything it then works and it resumes recieving IP's from 192.168.1.1
I have lost track of what "it" is. Is Wireshark recording packets from the machine that Wireshark is running on?
Wikipedia explains DHCP requests as starting with a "broadcast" to IP 255.255.255.255 and then waiting for the first DHCP server to respond. With the Orbi in AP mode, that should be the UBEE.
