Bovercome
Sep 11, 2020Tutor
DHCP Lookup Failed on RBR50 Orbi AC300
I'm trying to connect to my own network with a Chromebook the school district issued my child (Acer Chromebook C720 series). I keep receiving this "Network Connection Error" = Failed to connect t...
Sep 11, 2020Guru - Experienced User
Has the Chrome book been updated?
Try setting a IP address reservation on the RBR if the chromebook connects and see if it helps.
Try a reboot of the RBR and the chromebook.
If your other devices connect, then something with the chromebook needs too be looked into.
Contact Google as well for help an information on there product.
- BovercomeSep 11, 2020Tutor
How do I set an IP address reservation? I can see the IP address on the Orbi app. Just unsure of how to set a reservation.
My firmware on the Orbi is V2.3.5.30. Does this need updated?
- MstrbigSep 11, 2020Master
Bovercome wrote:How do I set an IP address reservation? I can see the IP address on the Orbi app. Just unsure of how to set a reservation.
Check your Chromebook network settings and make sure it is set for DHCP and does not have settings from a previous user.
- FURRYe38Sep 12, 2020Guru - Experienced User
ON the RBRs web page under Advanced tab/Settings/LAN Setup. Select Add and then find the chromebooks IP address listing. Select it then Select ADD, then select Save.
