DougB628
Jan 24, 2019Apprentice
DHCP not working properly, log filling with DHCP assignments
So I have noticed that after rebooting, sometimes DHCP doesn't work properly. No devices that use DHCP, whether they have a DHCP reservation or not, get DHCP assigned IP addresses. Whenever this prob...
ekhalil
Jan 28, 2019Master
DougB628 wrote:
To me, it seems that the problem lies in the DHCP Offer packet sent in response to the DHCP Discover packet from the client. The client, for whatever reason, either doesn't get the DHCP Offer packet, or can't read it properly.
DougB628 Thanks for doing a thourough troubleshooting anf for the good analysis.
I'd look at this differently. I think that the fact that Orbi does not reply to the DHCP Discover packets makes me think that those packets were really sent to another element in the network. Does the ISP modem/router provide any routing functionality? Do you have any other network elements (like extenders, repeaters, ...) that can supply DHCP functionality that can cause such an issue?
- DougB628Jan 28, 2019Apprentice
My cable modem is an Arris Surfboard. I purchased it myself from Amazon, it was not provided by my ISP. It definitely has no DHCP functionality. No other devices on the network that can provide DHCP, at least not that is enabled. The other indication that it is the Orbi's problem is that it resolves itself after resetting DHCP a few times. Sometimes only one reset (turn off DHCP, apply, turn on DHCP, apply) is needed, other times it's two, three, or four times. Once it stablizes, it's 100% good for quite a while. I'm still learning what changes I make can trigger at least partial resets of things, and there are definitely things that appear to reset DHCP (I see my phone lose its wifi in these cases), and then it's a crap shoot as to whether it will come back stable or not. So I've definitely learned to leave everything alone if its working. I need to build trust back up from my wife - at this point she thinks either that I just want to play with it, and don't give a damn how it affects everyone, or that I truly have no clue what I'm doing. I know the first one is not right... jury is still out on the second...
- FURRYe38Jan 28, 2019Guru - Experienced User
What is the Mfr and model# of the ethernet switches are you using in the configuration?
I have three switches, they are all TrendNet unmanaged switches. Two are model number TEG-S82g H/W:V2.0R, the other is model number TEG-S80g H/W:V2.1R
Only one of the TEG-S82g switches is actually in use at the moment. All three of them are 1GB/100MB/10MB capable.
Oh - one more thing - the Orbi is definitely replying - I see tons of DHCP Offer lines in the Wireshark log coming from the Orbi. It's the clients that are not sending the DHCP Request after that that is not happening when this is not working. When it is working, I see the following sequence for each device:
Device Orbi
DHCP Discover------>
<-----------DHCP Offer
DHCP Request------>
<------------DHCP Ack
When it is not working, The client sends the DHCP Discover, the Orbi sends the DHCP Offer, but most of my devices are not sending the DHCP Request after that. So it breaks down at that point.
- ekhalilJan 28, 2019Master
DougB628 What wired devices do you have connected to the Orbi Router and Satellite(s)?
Western Digital My Cloud 4TB NAS
Toshiba Satellite Laptop
Apple Mac Mini
Philips Hue Bridge
Lenovo Desktop PC
Raspberry Pi 3
D-Link NVR-312L network video recorder - capable of doing DHCP, but is disabled
Tablo OTA DVR
Apple Time Capsule (all wireless disabled, running in bridge mode so no NAT or DHCP)
I confirmed the configurations of the NVR-312L and the Time Capsule prior to sending this.
