DougB628
Jan 24, 2019Apprentice
DHCP not working properly, log filling with DHCP assignments
So I have noticed that after rebooting, sometimes DHCP doesn't work properly. No devices that use DHCP, whether they have a DHCP reservation or not, get DHCP assigned IP addresses. Whenever this prob...
DougB628
Feb 07, 2019Apprentice
So I've been shopping switches lately, and it seems that most of them tout IEEE energy saving features. If the "green" switches are in fact contributing to my problem, how do I know what type of switch to get? For example, the Netgear GS316 16-port Gigabit Ethernet Unmanaged switch includes this on its data sheet:
- 802.3az Energy Efficient Ethernet (EEE) compliance
Will this be a problem? If not, then what is it about the "green" swtiches that causes the problem?
Feb 08, 2019Guru - Experienced User
NG older GS series switches with the BLUE metal cases are ones to look for that don't have "green ethernet".
https://www.netgear.com/support/product/GS108v4.aspx
https://www.netgear.com/support/product/GS116v2.aspx
I also use D-Link's DGS 105/108 and HP Procurve 1400 series switches, a 24 port and a couple 8 ports. These don't have green tech in them.
- DougB628Feb 08, 2019Apprentice
The D-Link DGS-108 definitely has "green" technology. I've attached a snapshot of a portion of the data sheet from Amazon.
I've ordered the Netgear GS116NA which is the North American version of the GS116v2. Should arrive Sunday, and I will replace my current switches with that one.
- Chuck_MFeb 09, 2019Mentor
I use the GS116 as well and it works great with my setup.
- FURRYe38Feb 09, 2019Guru - Experienced User
Hm...I hadn't seen that with the 108. My 108 and 105s all work ok with my Orbi. Hmm..
Anyways, let us know how it goes with the NG switch. Hopefully this will resolve this problem your seeing.
