RedBatman89
Aug 07, 2021Guide
DHCP requests not logged
So I have been experincing what another users has been experincing as well starting last year. https://community.netgear.com/t5/Orbi/DHCP-requests-not-logged-consistently/m-p/1871331 Like him...
CrimpOn
Aug 07, 2021Guru - Experienced User
(I aplolgize for this seeming silly, but can you check on the Advanced Tab, Administration, Logs, to see if the Log Wireless Access is checked? (see attached image)
I found a post from March, 2019. Message 25 of the thread talks about this feature.
https://community.netgear.com/t5/Orbi/Orbi-not-logging-activity-as-specified/m-p/1652338
I also see suggestions about:
- Making a backup copy of the Orbi Config
- Doing a Factory Reset
- As soon as possible in the setup, restoring that Config, which will cause a reboot.
(In other works, do not set anything you don't have to because loading the saved config will just wipe it out.)
RedBatman89
Aug 08, 2021Guide
Yes it is.
