OrbiPhilip
Mar 05, 2020Luminary
DHCP reservations not working
Yesterday I added a raspberry pi to my network (running Nagios/NEMS). Every time it rebooted it took the next IP in sequence. That shouldn't happen... Instead of fighting with it, I created a reserva...
- Mar 05, 2020
I likewise had this issue, and a reboot of the router corrected it. I reported the issue to NG support, and they claimed the system firmware is "glitching" causing this. They admit that the firmware is still a bit buggy with v2.5.1.8 on the RBR50, but have no ETA on when they will have a stable and reliable mesh network.
OrbiPhilip
That was the first thing I checked. MAC is consistent. Reboot fixed the problem, but the DHCP entry still does not appear in the logs.
It appears these things now need daily reboots. Unforunately, no scheduled reboot feature exists. Or a log of DHCP reservations. Or....
schumaku wrote:OrbiPhilip some RasPi distros or redy-to-run environments are configured to change the network interface MAC addresses with every boot.-
CrimpOn
Mar 05, 2020Guru - Experienced User
OrbiPhilip wrote:That was the first thing I checked. MAC is consistent. Reboot fixed the problem, but the DHCP entry still does not appear in the logs.
Can you please clarify:
- The Orbi log contains DHCP assignments for every device except this one, or
- The Orbi log contains no DHCP assignments for any device
Thanks
- OrbiPhilipMar 05, 2020Luminary
Can you please clarify:- The Orbi log contains DHCP assignments for every device except this one, or
Before reboot the log contained many DHCP entries in the form of:
[DHCP IP: 192.168.1.xx] to MAC address xx:xx:xx:xx:xx:xx, Friday, February 21, 2020 17:35:58
Not none matched the IP or MAC of the Pi.
After reboot I connected to the Pi on 192.168.1.59 and rebooted it. It leased the address listed in the reservation (192.168.1.56). The log after reboot contains *no* DHCP entries.- OrbiPhilipMar 09, 2020Luminary
One problem that the Orbi system seems to have is the lack of ability to manually drop a DHCP entry from the table. As such, any device getting a DHCP address will continue leasing that address until the router is rebooted.
This is especially problematic when you give a device (including the Satellites) a DHCP reservation for an address other than the one auto-assigned. Anytime a given MAC is added to the reservations list, it should be dropped from the database if the IP changes.- CrimpOnMar 09, 2020Guru - Experienced User
OrbiPhilip wrote:One problem that the Orbi system seems to have is the lack of ability to manually drop a DHCP entry from the table. As such, any device getting a DHCP address will continue leasing that address until the router is rebooted.
This is especially problematic when you give a device (including the Satellites) a DHCP reservation for an address other than the one auto-assigned. Anytime a given MAC is added to the reservations list, it should be dropped from the database if the IP changes.I concur that this appears to be what happens. I do not know if it is a coding issue or if Netgear is following some "industry standard behavior" that I have yet to find. To MY mind, when the administrator creates an IP reservation for a MAC address, the system should immediately force the device to that IP address by sending A brief search for DHCP standards documents reveals:
RFC 1541 (1993) https://tools.ietf.org/html/rfc1541
RFC 2131 (1997) https://tools.ietf.org/html/rfc2131
RFC 3203 (2001) https://www.ietf.org/rfc/rfc3203.txt
This document defines extensions to DHCP (Dynamic Host Configuration Protocol) to allow dynamic reconfiguration of a single host triggered by the DHCP server (e.g., a new IP address and/or local configuration parameters). This is achieved by introducing a unicast FORCERENEW message which forces the client to the RENEW state.
In the "Linux world" once modules are coded, there is little interest in reworking them. My GUESS is that the DHCP code in OpenWRT (the basis for Orbi) simply does not incorporate this RFC.
Every time this phenomenon "bites me", it is a real chore to restore order. I keep an old cell phone for this purpose.
- Turn off the offending device that has picked up the wrong IP.
- Go into the LAN web page and assign that wrong IP to the cell phone.
- Power up the cell phone and connect. Now the cell phone is on that IP because when Orbi ARP'd, nobody said, "Hey, that's me."
- Now, power up the offending device. It asks for an IP. Orbi sees that it doesn't have one. Orbi gives it the IP out of the table.
- Cell phone goes back in drawer until next time.
