OrbiPhilip
Mar 05, 2020Luminary
DHCP reservations not working
Yesterday I added a raspberry pi to my network (running Nagios/NEMS). Every time it rebooted it took the next IP in sequence. That shouldn't happen... Instead of fighting with it, I created a reserva...
- Mar 05, 2020
I likewise had this issue, and a reboot of the router corrected it. I reported the issue to NG support, and they claimed the system firmware is "glitching" causing this. They admit that the firmware is still a bit buggy with v2.5.1.8 on the RBR50, but have no ETA on when they will have a stable and reliable mesh network.
Mar 10, 2020Guru - Experienced User
If you think that. Thats fine. My record shows other wise.
Been long time known that NG engineering doesn't follow forums. Moderators maybe. Again, users need to let NG know is all i'm saying.
Good Luck in your endeavours.
OrbiPhilip
Mar 10, 2020Luminary
FURRYe38 wrote:If you think that. Thats fine. My record shows other wise.
Your record shows spamming and useless drivel. Maybe 5% useful content, if I'm being very generous.
- BoilerPlateMar 10, 2020Apprentice
And we see your history is nothing but complaining and badgering other users. Thats very helpful. 100% and i'm being generous.
- OrbiPhilipMar 10, 2020Luminary
BoilerPlate wrote:And we see your history is nothing but complaining and badgering other users. Thats very helpful. 100% and i'm being generous.
Oh really?
OrbiPhilip post stats
Total Messages Posted - 96
Total Kudos Received - 69 (71.9%)
And for comparison:
BoilerPlate - 20.8%
Furrye38 - 9.5% - OrbiPhilipMar 16, 2020Luminary
Apparently Orbi makes very little effort to maintain lease history and/or attempt to reissue the same addresses. Since employing Nagios a week ago I've watched two devices change IP addresses without explanation. This should not be happening since we aren't even remotely close to the number of addresses allocated.
Note: If you are running TiVo, you will need to create reservations for all source (i.e. DVR) devices on your network. If a source device changes addresses it screws up the TiVo beacon process (Bonjour/zeroconf) and you will need to repeat guided setup on all remote (i.e. mini) devices.
