OrbiPhilip
Mar 05, 2020Luminary
DHCP reservations not working
Yesterday I added a raspberry pi to my network (running Nagios/NEMS). Every time it rebooted it took the next IP in sequence. That shouldn't happen... Instead of fighting with it, I created a reserva...
- Mar 05, 2020
I likewise had this issue, and a reboot of the router corrected it. I reported the issue to NG support, and they claimed the system firmware is "glitching" causing this. They admit that the firmware is still a bit buggy with v2.5.1.8 on the RBR50, but have no ETA on when they will have a stable and reliable mesh network.
BoilerPlate
Mar 10, 2020Apprentice
And we see your history is nothing but complaining and badgering other users. Thats very helpful. 100% and i'm being generous.
OrbiPhilip
Mar 10, 2020Luminary
BoilerPlate wrote:And we see your history is nothing but complaining and badgering other users. Thats very helpful. 100% and i'm being generous.
Oh really?
OrbiPhilip post stats
Total Messages Posted - 96
Total Kudos Received - 69 (71.9%)
And for comparison:
BoilerPlate - 20.8%
Furrye38 - 9.5%
- OrbiPhilipMar 16, 2020Luminary
Apparently Orbi makes very little effort to maintain lease history and/or attempt to reissue the same addresses. Since employing Nagios a week ago I've watched two devices change IP addresses without explanation. This should not be happening since we aren't even remotely close to the number of addresses allocated.
Note: If you are running TiVo, you will need to create reservations for all source (i.e. DVR) devices on your network. If a source device changes addresses it screws up the TiVo beacon process (Bonjour/zeroconf) and you will need to repeat guided setup on all remote (i.e. mini) devices.
