vrtladept
Jul 09, 2019Tutor
DHCP Server is buggy
Just a friendly message because it may help others. I'm using an RBR50 with 1 RBS50 sattelitte on firmware V2.3.1.60 ... I've been having a horrible time with the smart switches in my house (I have a...
- Jul 19, 2019
I just noticed the new upgraded firmware (V2.3.5.30) and in the release notes is this fix:
[Bug Fixes] The client was not able to obtain an IP address when the router rebooted or the client renewed the IP address
I'll try to update over the weekend when I have some time, but this seems like a likely fix to my issue since my problem was that subsequent reboots of my large network always ened up with some devices unable to obtain an IP Address (with different numbers not working each time). I'll report back if this fixes it, but I'm hopeful.
Jul 17, 2019Guru - Experienced User
Also could be a possible issue with your network environment or maybe faulty HW. There many various network environments and HW that could be a cause. With out more investigation, hard to tell and cant' really point to only Orbi.
Most Orbi systems are working for Orbi users and DHCP is working for them. Mine as well.
Good Luck.
vrtladept
Jul 19, 2019Tutor
