Beckygentile
Mar 19, 2019Aspirant
DHCP wan disconnect
I have the router and the satellite. When I first set this up within 4 hours the router would not get or keep an IP address from cable modem. I returned the product for a new one and 9 days later s...
Beckygentile
The firmware was 2.10.10 - found the new firmware and manually loaded it last night - hoping that solves the problem.
Modem mfr - I will have to look when I get home. It doesn't give me those details online.
We have a 300/20MBs connection.
Orbi is acting in router mode - satellite is actually connected via CAT 6e
The satellite works great- everything does, but then this happens out of the blue.
Mar 19, 2019Guru - Experienced User
Ok, let us know about the modem when you can.
If you have the satellite connected via ethernet cable, you can disable Daisy Chain, Under Advanced Tab/Advanced Settings/Wireless Settings.
Hope it works better for you.
Beckygentile wrote:
The firmware was 2.10.10 - found the new firmware and manually loaded it last night - hoping that solves the problem.Modem mfr - I will have to look when I get home. It doesn't give me those details online.
