truefan34
Oct 16, 2017Tutor
difference between connecting 5 ghz wifi on orbi vs ethernet connection to satellite?
Is there an advantage? Connecting by ethernet to the satellite, does that yield better speed/lower latency than connecting just to the 5gz wifi broadcasted?
DarrenM
Oct 18, 2017Sr. NETGEAR Moderator
There could be a advantage because you are not using another wireless connection speeds could be better.
DarrenM
